Improve your scooter range
Follow these tips to make the most of your scooter
Watch this video for a step by step process.
5
Cell balancing. After 100% charge don’t unplug your charger, on side of your charger there is a small light inside it. After finishing 100% still that light is glowing red colour means it is doing cell balancing. Once it can tyrn into green you can unplug the charger. Generally it is taking 25 to 30 mins to do cell rebalancing after 100% charge
very good tips , thanks for sharing, will charge it accordingly this time
For better battery life u shouldnt charge 100 percent… Should charge when battery falls to around 20 to 30 percent and stop around 90 percent… Thats wat i heard
@Janeeta_Thomas That’s true. The ideal range of operation for Li Ion battery is said to be between 25 and 75 percentage. This is said to extend the life of your battery. Recharge at 25 and cut off at 75. I use a smart plug and reduce 2 hours from the full charge time, which turns off charging at 75%.Eg. If full charge is indicated as 10 pm, schedule power off at 8 pm and it will be turned off when it gets 75% charge.
NB: This is applicable only if your travel suffice with 75% charge (103 kms)
Ola s1 runns only 70 km in full charge? What to do now.
My Ola s1 hardly gives 65 km only with 100% charge…is anybody getting the mentioned numbers like 100 in Normal mode
My Ola S1 Pro runs 65 to 70kms using all 4 modes depending on city traffic. Must I improve it by doing something or must I contact support?
I am all so new user in 100 percent s1 pro given only 85 to 90 km in normal mode
Below 30 percentage automatically changed modes like normal and eco
It will get Maximum kms only 90 i think in 100 percentage
Hi,
I am also facing the same issue.
Most probably it gives less then they promise.
I wilsuggest to improve it…
I am getting close to 125km on normal mode. I try to use regen brakes. Currently on move os 2.0. Waiting for move os 3.0 so I can test the range with high regen feature.
I am getting range of 120km in normal mode but the speed has to be within 50km/h and the Bluetooth has to be off or shouldn’t be connected with mobile.
Don’t use break use regen avoid over speed
And avoid throttle over
Use eco mode for more range min 120km
What’s smart plug. Where did you buy?
I am using my Ola s1 60 to 65 % in eco mode to be I am getting 80 to 90 km in full charge. What to do
[quote=“Bhalodi_Siddharth, post:7, topic:369”]
[/quote]for me it’s give 135 km in eco mode my speed is 40 and linear acceleration.
Smart Plug helps you to monitor and control the electric power supply to the connected device. You can connect it to the scooter to measure the power consumption.
You can purchase it from any retail shops or online.
If we charge on 25% and maximum charging 75% then what’s is the mean of autocut ?
I have taken delivery of ola s1 2 days before nd it will run 70km in full charge on normal mode .What to do for more range?
Auto power off using smart plug at 75% of charging will extend your battery life. When the charge comes down to 25%, plug your charger through the smart plug and set the off time 2 hours before the time shown for full charge in the scooter’s display. This will approximately be the time to reach 75% charge.
