Charge your scooter
Connect your charger and monitor your battery levels.
Check out this video for the simple steps to follow to charge your favourite Ola S1.
6
Quick Tip: After 100% fully charged, remove the charger from scooter.
Then reboot the scooter you might see drop in charge percentage, now connect back the charger and charge it again till 100%.
Once it is charged 100% remove the charger and reboot once again, now it mostly stays at 100% without any drop in charge percentage.
Like this post if you tried and got the 100% charge.
how to reboot?
Long press start and reverse buttons on scooter to reboot the scooter
Is cell balancing recommended?? Does it really help in preventing charge drop? Im doing passive cell balancing havent seen any,significant change.
Does charging 100% every time reduces battery life?
After full charge its better to alert through alarm sound in moblie app instead of notification and its getting difficult to notice the notification
Some people charge the scooter over night
I don’t think it’s good for the scooter battery health
I noticed when you leave your scooter For 4 5 hours unused your scooter Automatically goes into sleep mode where the Temperature goes down to 27° to 25° Celcius but when you use it Normally The Temperature is around 30° to 35° Celcius
I think sleep mode is very important for scooter maybe it cools downs the scooter and shut of all the components partially no range drops after sleep mode
Charger saftey no at the rain
Is that ok for charging suddenly after the run
Check your scooter temperature.
If you think it is high, better to cool down before connecting the charger. else nothing wrong in connecting the charger after the scooter ran.
Does any problem riding on rain
Use a timer to charge your scooter to 75% so regen braking always works
It also extends battery life, and is a feature built into every Tesla car.
I use a cheap 6a smart plug that works with my phone. It also gives me the amount of energy used.
Formula to use for charge minutes = (75 - current charge) x 3.5
So if your bike has 22% remaining then charge time is 53x3.5 = 185.5. Use 3 hours 5 min on timer. This is for S1 pro.
Hyperstation in Surat?
Hyper charger​:battery::electric_plug: in visakhapatnam??
From where do we know how much time is remaining for complete charging of s1 pro?
Yesterday for a full charge i ride only 58 kms on normal mode, don’t know what to do,any suggestions for a greater mileage?
Pls send name of cheap 6a smart plug
In S1 Pro full charge in normal mode it’s give only 90-100 km, how to get 137 in normal mode
Can I run continue in eco mode full day
Is it recommended to charge OLA S1 Pro over night?
Yes you can be if you daily drive vehicle… Charging will auto cut off
