Improve your scooter range
Most of here experienceing range issue? Can ola team or someone share all the best practices here, I m using S1 Pro and getting range aound 90 kms only in 100 % charged
I’m facing the problem in ola S1 that it’s battery draining by 2-3% during night time.
My s1 range 75
You can buy online…
I can provide link to buy from Amazon
https://amzn.to/3XY1RaS
I think we all OLA users should track the Battery/Range of our scooter with help of Excel sheet and formula, so that we can get the exact performance of scooter and battery.
Hope so you all will like this.
Keep an eye on your Scooters Tyre Pressure, maintaining correct tyre pressure is very important for proper rolling of your scooters wheels ! Recently I faced range drop in my S1 pro for 2 - 3 days, all because of a very small puncture lost tyre pressure, pickup & rollover, because your scooter has tube less tyre it will take 3-4 days before you actually notice the puncture.
Once the puncture was filled up now it’s back to normal range, I get 90 Kms in sports mode, 120 in normal mode.
If we charge full battery 100 %
And drive in normal mode if we drive with single person my self
It’s shows -135 km in starts but it runs only
Accurate 115 km and if we are going double when we start with 135km it will cover only -95 km to 100 km
I have S 1 pro and getting a good range . Before starting I ensure 100%charge , tyre pressure optimum, normal mode and after getting Mov 3 update I had put it in max regen mode. It gets activated when battery comes below 90% and to get activated press both breaks together. It not only makes your ride comfortable but saves frequent brake using and also charges your battery while driving. At least in one full charge you gain 7 to 10 km ( in my 34 km up and down driving back to home) . Check out .
we are riding 2 people I’m using in normal mood and I changed 95% and i got 95km in my S1pro i think i will single it’s gives me 120km-125km I’m satisfied with my S1pro
OLA S1 Pro minimum Range 100 Km in fully Charged… My practical experience with 14,000/- KM. experience. With Normal Mode only Range between 55-75 km hrs.
My daily running 65 km to 90 km.
My ola S1 range is about 50 to 55 km max range in full charge.
Today my scooter temperature was showing 36°,all day i will park scooter under direct sunlight,is there any danger if temp show that much or it is normal ?
Sir my Ola s1 pro is giving a very good range of 165 & 135 in Eco and Normal mode. But in Sport and Hype mode it is consuming more the 1.5% > even with smooth and high us of regen driving. I us regen for braking almost all the time.
This is very bad that v can’t relay on what the range reading is telling us in Sport and Hype mode. Traveling for 50kms on side destinations and challenging to achieve the range of sport and hype mode is very much complicated. Please we need much much more improvement in updates with Ola Sport and Hype mode driving.
We all customers of Ola want to enjoy Sport & hype mode happily. Please give us update of software or any machaical changes abt this ranges in Sport and Hype modes
My Ola s1 hardly gives 65 km only with 100% charge…is anybody getting the mentioned numbers like 100 in Normal mode
yes , i got more than 90 with a pillion, so I guess 100 can be achieved with a single rider
Speed maintained 45-50
Before start of your ride get the screen shot of battery and range .
Do this practically with every ride and at every halt
This willl definitely help you out to know the ridding pattern which can give you optimize range.
Daily 100%charge se charging cycles juldi khatma hote hai battery have limited charging cycles
I think best technique is to not focus on charging and range.
Just make sure you are keeping the vehicle in good condition with regular charging, proper air in tyres and time to time cleaning.
Do not throttle excessively, use regen for slowing down and gradually increase speed and use normal or sports mode only if needed.
