How get mileage olas1 pro
My ola s1pro gives 75 to 80 km full charge in normal mode . how can get more mileage give me solution
Today I checked my Ola S1 pro mileage, before falling low battery level, I got 126 kms on a single charge. I used cruise control and traveled at 35 km/h average speed. I traveled on highways.
drive it in eco mode i mainly change mode while driving cos sometimes need accerlation in Traffic and in riding mode low to regresstion mode cos in default mode scooter apply brake own when u release Throttle and scooter stop soon as soon possbile but low mode u can release without Throttle your scooter reach to 100 meter without accerlation or brake
Even my Ola S1 pro gives me 85 to 95kms on full charge. Even i tried regenerative option, minimal throttle and driving in Normal mode. No change
I got a range of 140kms on my scooter in a single charge crusing with a speed of 50km/hr. Switch to High regen while driving Try to use force regen maximum instead of braking do not give sudden accelaration or sudden braking that will reduce the performance of the battery and brake pads will be worn off very quickly. Do not use flyovers when you are planning to get more range. Travelling on a flyover will have to face more wind resistance that consumes more energy from the battery. Try to travel in the morning if you are planning to have a long ride that will help you to travel in a relaxed manner and this also help in maintaining the battery temperature. When the temperature increases even the range of the scooter will also be dropped.
My S1 give 80km range
1-Use regen braking by reversing the throttle to slow down the scooter, instead of using manual brakes.
2-Keep advance regen braking to low in riding mode, so it won’t pull your scooter unnecessarily.
3- if your riding regen is low then if leave throttle it will go upto 100-200 meters automatically without throttling, if there’s a sloppy road the it will be more battery saving upto 500 metres can go.:blush:.
4- if you have S1Pro then activate cruise control on straight roads…
With these tricks I’m getting more than 110Km in one single charge on my S1 not S1Pro…
Once contact with service people that may be problem of Motor Control Unit. I also faced same problem and the vehicle also automatically going to eco mode after driving 20km in normal mode. Ibut in normal i didn’t face any problem. I strugled with this issue for 8 to 10 months.So i contact serivice people they said there is problem with MCU & they replaced. Now its working perfectly.
Check the tyre pressure of both tyres
