Today my ola s1 pro reang normal moad
Good. Where are you from ? Share your ride dwtails here . It might help other .
I got 139 KM on One charge and Still i had 22 Percentage battery left , so i got approximately 160-170 KM Range that day in Normal Mode smooth driving.
Can we continuously ride in eco mode …?
I have started journey with 90 percent battery. Total 76 km travelled. Most of Journey in Eco mode. Now only 23 percent battery left.
It is usual for me, it gives around 130 km in normal mode. ECO mode is not useful, drive smoothly in normal mode and you will get more than 130 km easily.
Im form hassan Karnataka
Rajat what speed will ride in normal moad
It is possible…
When you are driving sigle seat without pillion and have kept regenerative mode on default or High follow just 3 instructions specified below.
  1. By using regenerative mode instead of braking and also in case of urgent braking reverse your accelerator while applying brakes. This will preserve your battery.
    Note : Make this your habit if you are driving OLA S1 pro very often.
  2. Do not over accelerate for pickup, everytime you switch to ride mode from parking mode, you just slowly and gradually accelerate your OLA 1 Pro. This will not take sudden power from the battery which will again leads to preserve your battery for long range.
  3. Ride continuously without much stops with consistent speed(keep your speed between 40 to 60 km per hour for consistent battery preservation and to get a long range), this will also preserve your battery because when you are riding at a consistent speed or you are using cruise control which is now activated for the speed below 47 , I have personally used it on 34 and 36 km per hour of speed, this will automatically preserve your battery because you have already taken a specific speed in this situation motor does not take much battery power to accelerate your scooter.
Following all these instructions you will definitely see noticeable change in your range.
I am riding only normal moad 55 to 60 speed.
