How much range ola s1 pro give in normal mode my s1 pro giving around 100km in normal mode i drive 65 km and battery goes decrease to 29% i am using sport mode only 2km in 65 km
Drive around 50 kmph , Check your tire pressure , Use Regen to slow down. then test range
Its normal range that you are gettingą„¤
If you are under 70kgs,and drive at about 40 than in normal you will get near to what ola saysą„¤
I am 120kgs,six foot tall and i get about 65 in normal mode with full vroom vromm and i am satisfiedą„¤
I get efficiency of around 1.38 km per 1 percent on Highway with pillion rider and total weight on Vehicle was 130kg used Cruse Control maximum time with 50 to 55km per hour speed. With Tyre pressure around 35. Regen settings kept at highest.
And efficiency of 1.7 km per 1 percent with 80 Kg of weight riding in above manner.
