S1 pro 82 Km on full charge
Around 120 km
No even i was having that issue without knowing how to accelerate .if you accelerate correctly it will give up to the range trust me.
I get renge in normal mode 140 km
I am getting 100km only in normal mode for full charge
My weight is 95 , i got the range between 90-110 , the road is not straight, iam happy :blush: tyre pressure is an important role in range, 33psi both
I got 140 km range on normal mode
Got mine two days back. It was charged 86% when I took the delivery and have ridden 70kms with 26% still left. I weigh 85kgs and in that 70kms, 20kms was with a pillion.
So it all depends on your riding style and the throttle input and the weight you carry. When got a chance I use regen braking extensively. So I expect 130 kms on full charge as per my riding style.
Yes
I got 185km in eco mode at speed 24-30kmph
Speed matter
Yes…same here
I weight around 65kg and in normal mode single passanger easily getting 120km range
Ola scooter mileage is dependent on the weight of the rider…person with weight below 70 kg will get good mileage more than 100 km
On Eco mode I can cover around 150+ km and Normal Mode- 110+ km. You need to change your driving style.
yes this is truely range on hyper & sports
i get 100 to 110 km range
I got 130 km on normal mode
Yesss
There’s no problem using extension. Direct socket is better because there will be less resistance.
Im getting 65-70kms in 100 to 20℅charge in s1. Once it shows 20℅, i put it for charging.
