Should we unolug charger after its fully charged
@OLA please i have a serious doubt as they say you should remove your charger that is unplug as soon as the scooter gets 100% fully charged. But sometimes when i charge late night , i sleep and forgot to remove charger, the charging is normally done at 1am night but as i forgot i unplug it in morning 6/7am. So is it fine, so it can create a problem, please let me know @OLA
It’s absolutely fine as it will cut off charger automatically
right i say the same…
You can unplug charger anytime unless your electrical wiring are protected from voltage fluctuations & properly earthed. Most time BMS takes care of everything. If so much worried use a voltage stabiliser.
