Can I charge Ola S1 Air scooter overnight? Is there any problem
depending on your usage you can absolutely charge overnight if needed.
keep in mind that battery chemistry degrades if kept charged for long time.
If you use >80% in a day and >20% just few hrs after fully charging it’s fine.
The scooter will auto cutoff charging after 100% and resume when it get down to below 99%.
if you are using less don’t charge above 80% so you get get better battery life and hopefully more cycles of battery It’s general rule not only for ola but any lithium ion battery devices
No problem but u ll get noticed thru app and msg after full charge then switch off the charger
