OLA S1 PRO Range
My S1 PRO has been getting only 85 KM range. I ride alone and mostly within 45Kmph. Does anyone know from their experience what am I doing wrong?
In which road conditions you drive ola ev and Rider’s weight also matter.
1.What’s your weight?
2.Tyre pressure?
Tyers pressure check kr lo
125-130km range surely in 45km/hr
You should go and get it checked at centre. I dont think its normal.
In normal mode and on single person range is easily around 100km.
Although i have not driven that much in single charge I only ride once around 85 kms with dual persons and it left around 9% battery left.
My weight is 70kg and I drive it on clear and plain roads in suburban area. I always maintain the tyre pressure between 33-34. My daily commute is ~12km hence I have to charge it every 7th day because battery would drain out once I cover 80km.
