Hi All,
As a suggestion, can we up-vote this to get a update on Ola Electric app to get notification for charger removal/disconnect and connect. This will be very helpful while charging in office or any other public place where someone can remove the charger.
Please share your thoughts.
Yes it is required, it was working before after OS3 update, it stopped that notifications
This feature is great, it helps me too. When the vehicle is being charged and you are away from it, then as soon as the vehicle is charged, with the help of POPUP MSG near you, you will know that the vehicle is being charged. It has been disconnected and with the help of anyone, you can disconnect the charger related to the power supply by turning off the supply from the plug.
Better for security ground
I had kept scooter for charging in the parking and someone disconnected …
I cameto know when i went down…
Notification with ringtone in mobile will help alot
Yes charging notification is required
Also notification on alaxa and Google home
Yes I am also into your suggestion
Yes I pol for this feature in which there should be notification of charge out or in the scooter like switched on or switched off notification
Yes charger disconnect or power supply failure notification required while charging Ola.
This is a must have. I guess they can do something on this from the software point of view.
Much needed feature, also need a feature to get real time charging status on App
Should be implemented asap as it doesn’t require any additional development.
