Battery drains daily for 2% when not using it. Can’t we stop that?
When we don’t use it for 12hrs -24hrs, battery will drain for 2%. In this case if I charge for 100% and starts using it (suppose daily 5km) I can’t use the 135 km completely. 50% will go un used.
Is there a remediation for this issue?
In move OS 3,there is vacation mode which will save your battery.
There are things running in the backend even when your scooter is off… So now in moveos3 you can use the vacation mode for batter not to drain
Vacation mode is not for a daily use I guess. Fir long term it is good. I believe background updates should be done weekly once to avoid this issue.
