Use light & indicators
Learn how to turn on/off and switch between different light modes & indicators
Check out this video now!
4
Waiting for move os3
Can we switch on Halo only? Is there any update in OS 03?
No, one low beam light will always be turned on, as it is mandatory by law now
Can i switch off head light in day time?
Please add Hazard Light option, where both the indicator blinks together.
No
Very much needed
Can we decrease or disable the Turn indicator sounds and reverse drive sounds. . Presently these warning sounds are very high
How to decrease volume or diable these warning sounds
+1
No
No
No
Can we switch on DRL LED LIGHT only?
Kindly update 4 way indicator.
Keep DRL light on default instead of low beam.
Only drl lights is must on the run
In os 3 we’ll get hazard
You can switch on halo only when you park the scooter. While running as per law the head lamp should be on
Only in the DRL no low beam always on
