Scooter Feature Suggestions in Goa
Drop us a line of suggestions on future Ola S1 features. We’d love to hear from you!
Scooter location on the ola electric app please?
Trip meter to know about the particular distance you have covered. Tracking of the vehicle via ola electric app.
Hi, we need the following features on the Ola…
  1. Manual Trip Meter - Remove automatic trip meter reset on locking of the bike. Allow user to reset at his preference.
  2. Live Bike Location/Tracking - Allow user to track bike love location.
  3. Add security/Alarm/Push notifications when anyone tries to figit with buttons or the bike when locked.
  4. Allow user to control bike headlight through Ola Electric Mobile App.
  5. Automatically switch bike from Eco to Normal mode when climbing on steep hilly regions when certain speed threshold is hit.
  6. Add more moods/themes with more touch functionality on Home Screen.
  7. Allow override mode where the user gets to select normal mode when battery is less than 15%(eco mode)
  8. Hill assist - provide unlimited hold in hill assist and not for a 3 second or so.
  9. Add silent mode - Enable user to turn off all system sounds including startup and lock.
  10. Make Horn button/Break light more responsive on pressing the button or pulling the break lever. There seems to be a 1 sec delay when you press the horn button or break led light.
I hope some of these features get picked up. Thank you Team Ola.
An option to open the storage even if the battery is fully drained.
It should have gps tracker
Enable a feature to set max limit of charging to safe guard battery. For example user can set 95℅, once charging reach 95% it will auto matically disconnect the charger.
  1. Increasing the auto boot re-lock time is suggested as most of the time when we are about to open the boot after unlocking, it gets locked again. The interval is very short.
  2. Activating regen braking with slight application of the brake levers, similar to reverse throttle, will enable brake light on regen brakes as well as ensure that regen braking is utilised before brake disks are used. This will also ensure ease of use of regen in conventional manner.
Need light in switch, becomes difficult at night time .
Cruise control for S1 to improve the range
Ola should provide an option of fast charger individually like the present protable charger so that the people in field work can use that charger instead of searching for hypercharger as it is low number of hypercharger available in banglore
