Day time running light
I do agree :+1:
I agree with you.There is absolutely no need of headlight in broad daylight.
Agreed there was no need of light in broad day light there should be a option of turn on and off the light it could save some battery
Absolutely correct! Battery saving tips should be implemented like this.
Mileage low due to headlight consuming more power
It un necessary consumes battery. Halo should be on and not the headlight compulsion.
Exactly! Halo light should save some watts as well.
Agree with you
Truly agree updation should be come in which light is off during daylight which helps in saving battery
It’s mandatory per law
I agree with you
Good suggestion and i absolutely agree with it
Even i think the same. Halo light will also saves up the battery.
I agree.
Yes i agree :+1:
Agreed
Yeah at morning it needs to off option
Yes, this needs to be implemented. Also for the headlight, they can auto switch in based on mood settings (there is a night and day mood option)
Agree. This should be fixed.
Absolutely
