Today suddenly I saw a lot of my range drop, weirdly I think it is because of the cold weather today , do you think it effects the range?
What was the temperature? Was it below zero?
Is real reng drop due to cold???
The temperature was around 18-20
Yes there was constant drop in range 2-4 kms drop
hi sir, there is No Matter like Range Drop issues with temperature, as it was well tested at BIC under all conditions & at various levels of temperature , i suggest you to change the way of throttling and maintain correct modes will surely give you the range of 135kms @ 100% level in Normal mode.
Range drop issue
