Charging port and charger
It is great to have a scooter with good mileage of above 130 km but sometimes we may need to go beyond and require charging. Several fast chargers of KSEB and other companies are coming up but they are of no use for us as ola uses proprietary charging gun. Kindly consider use of universal charging gun which would be great for customers.
They won’t do that as they already set up the infrastructure for this proprietary connector. Our only hope is that more manufacturerers will adopt this connector and have widespread chargers.
Hello i just purchased s1 pro
Is ola charger fan always running or automatically run…
Because i just connect charger and its fan not running
Hello Ola
The charge design has to change something like only cable should come out (retractable cable)from the scooter then it will be easy to charge.
Also charger should be smaller or downside cable should be long enough. So that managing charger for long time should not be issue.
Ola hyper charger shud b on touching highways .
Need hyper chargers out side the cities/hiway(between the cities)
If we can have convertible gun which can support from charger to ola charger,
or if Ola can provide 2kw home charger which will reduce charging time drastically
:100:
Any body in my location (Manikonda Alkapur Township Road no 16) who can spare charger have got issues with charger have submitted for replace it takes two days for replacement
