Is it possible to store the charger in the boot of the vehicle while charging so that people cant steal it easily? Will the charger overheat if kept in closed boot due to lack of ventilation? Kindly answer someone!
Yes you can keep the charger inside boot while charging
The seat and boot gaps has given two holes for both the wires the thick one and thin one
This Show the company want you to keep your charger inside boot that is the reason they given the holes
Even I tried doing that, but the charger and boot both gets heated up. After 30 min again I removed and kept the charger at open area as usual. The thermals are not good.there are chances of
. Don’t do that. Maybe ola can work on this aspect.
Same question
