Here are all the ways you can open/close the trunk
Ola should provide small light inside trunk
Ola should provide a small led in trunk
Ola Should Provide Small light Inside The Trunk Because if Put Some Storage In the Trunk They Can’t Visible
Trunk closes within few seconds. It has to be a unlimited time
I found my boot closed but on scooter it was open
When contacted ola team they told to reboot and the problem was solved. They told to always reboot after every charging to avoid such issues too.
If boot shows unlock but it’s locked try this. Sit on scooter properly at the lock place or try to sit on where a perfect press happens try in different places it will display as locked then you can open no need to reboot it works for me try it
