What features you want in the upcoming ola map app?
  1. True range that can calculate your range based on temperature and altitude data.
  2. need a map app that can tell you ‘RAILWAY CROSSING’ opening and closing time, while showing the rout. it gets annoying if you live near a railway station.
  3. Add suggestion rout features where your friends can remotely send their location directly to your map! So that they can guide you!
  1. Saving Route Option
  2. Planning Trip Option
  3. Way to add missing places on Map.
Google map
Leave map my india and switch to google maps
Feature to tag or save my favourite cordinates on map for later use via any mobile app.
Use map data from google. We are all eagerly waiting for that.
Boot open option in map view as in current layout to open boot you need to exit the navigation first.
Change the position of indicator light which blinks red while charging and turns green after full charge, on the charger from the side to front as it is not visible at current position when the charger is mounted on the wall
