Ola charging point Lock requirment
Yes… need lock system on dash
Yes it is required
Yes definitely required
Yes
Yes lock should be provided along with the rubber cap. The rubber cap has been removed in the newer models
Yes it is needed
Yes it’s necessary…
They removed it themselves from the new units.
Yes
Hi ola members i want to suggest to ola company about hyper charging station what ever the space you taken to stand the charging station you can install 3 or 4 plugs better than 2 because of the space 4 ola scooters can stand in a line with minimum space,
And MAIN POINT
{While charging scooters
Scooters will come by heat while riding
Ola bike owner should wait for minimum 15 minutes in shadow to cool the vehicle and charge it same process in home also after riding wait 15 min then charge it’s good to scooter and run long years
if it is RAINY OR SUMMER season while charging scooters in charging station ola company should provide SHEDD to station because while charging hyperly scooter will generate heat if it is in Sun heat while charging Blast chances are there
And If it is RAINING or ICE CUBES scooter electric components will be damaged or to the scooter bcoz it is all fiber plastic…****
Yes that’s true
That’s very true
Lick required
It is very important
It’s very much needed.
Need lock
Yes
Yes right ola need assistance here
If totally discharge you can’t open the charging flap and it won’t charge.
Yes it’s require
