Hypercharger in pune
Swargate is operational is what the ola champion told me as he came for service today. He tested himself today
Hi All,
Does any one know that charging station at Lonavala is working ?
I saw on the map one over there and is it just two points to charge or do they have more atleast over there ?
Hyper charging at swargate Pune…one port not working please fix asap****
Kindly update your experience of charging station available in Pune and nearby area.
This can help fellow riders during battery drain.
Any active hyper Charging Station at Pune.
Does anyone know how to speed it up? Does it also take so much time for you ? Are you using 5amp or 15 amp ?
It is same for s1 pro.
There’s only one charger that Ola has and it’s a slow charger. 5A. Hopefully with moveOS3 and new fast charging infrastructure in cities, you might be able to have fast charging. But that’s not going to happen soon as far as I understand
I am using 16amp but there’s no difference to take charging time , 16amps mostly recommended power socket
When coming in pune ?
Is the charging station working at Saraswati Auto Petrol pump in Pune?
Please change the hypercharging capacity of scooter to 50% on hypercharging. It is working at most speed till 50% then charging happens at slow speed. People are doing time pass to get it charge till 70% and other people have to wait for longtime. Better make it 50% more people will be happy. And there will be less rush on hypercharging station.
Also please give some helpline number on hypercharging station so that in case of any issue people can call the number.
